How much is this 92 'GT worth?!?
Here are the mods, it has 140k miles on the chasis, 1800 miles on rebuild.
[ul][*]306 Roller 400 approximate HP[*]10.5:1 KB Pistons[*]Polished race prepped rods[*]Race Prepped Block (By Tachyon)[*]Standard Crank (Prepped by Tachyon)[*]Roller timing chain[*]Crane Roller Rockers 1.6 pedestal mount[*]Comp 274HR Roller Cam [/ul]
.555,.565 lift / 224 232 Lift @ .050
[ul][*]Typhoon Intake (mildly ported, gasket matched)[*]Melling Oil Pump[*]BBK Long tube Headers w/ matching H-Pipe[*]Flowmaster 2.5" Catback exhaust[*]Under-drive pulleys[*]MSD Ignition[*]C&L 76mm Mass Air[*]24# injectors[*]65mm Throttle body[*]Aeromotive adj. fuel pressure regulator[*]Ford Racing Aluminum radiator[*]R-134 A/C conversion[/ul]
____________________________________
[ul][*]Heavy Borg-Warner T – 5[*]Pro – 5.0 Shifter[*]Dealers Equipment ceramic clutch[*]Steel input shaft retainer[*]Adj. clutch cable w/ Steeda fast ramp quadrant[*]Firewall Clutch cable Stabilizer[*]Ford Racing Aluminum Driveshaft[*]Competition Engineering Driveshaft loop[*]Sub Frame Connectors[*]BBK Lowering Springs[*]KYB Front Struts[*]New quick ratio steering rack[*][/ul]
[ul][*]225-50-16 Front tires[*]255-50-16 Rear Tires[*]BBK Fender Well Cold Air Kit[*]Polished valve covers (factory)[*]BBK rear control arms[*]3.55 rear gears[*]A/F ratio gauge[*]Fuel pressure gauge (electric)[/ul]
[ul][ul][*]Ready for nitrous up to 200 shot[*]VIPER Alarm[*]Sony CD player[/ul][/ul]
Its a 5speed, obviously too. Thanks a lot!!
[IMG]local://upfiles/16103/9D630CA5E54E427999570A6D29B1E3F5.jpg[/IMG]
[IMG]local://upfiles/16103/FF47DBED71904A99BF7D613894C70DA1.jpg[/IMG]
[IMG]local://upfiles/16103/7A10613252A549BB8B46A0877EF95218.jpg[/IMG]
[IMG]local://upfiles/16103/F6C059C96863498D834880ECE51A3468.jpg[/IMG]
RE: How much is this 92 'GT worth?!?
He told me he NEEDS to get 6500 for it, if he doesnt, hes gonna take the engine out of it, and put in a stock 302. I think I'll probably pick it up if it is really worth 7k.
I am new to fox body stangs, so I wasnt sure if it really worth it..
He's a good buddy of mine and I know he's not lying, if he says 6500 isas low as he can go, I'm not going to try make him go lower on the price. Does 6500 seem reasonable?
make sure the torque boxes are in good shape too and know that you will have to put in battle boxes and after market control arms upper and lower. adjustable shocks ect. if not your in for some bad cracking problems and you will play hell hooking up.
ORIGINAL: iceman89gt
