Fuel System for 450HP
RE: Fuel System for 450HP
I took the car to PSI and Patrick wanted to take off theFMU install Inline fuel pump,42lb injectors, MSD, Chip burn (tune),and of course a smaller pulley to cranck up the boost.
Is this my best bet or are there other options?
ORIGINAL: AdderMk2
lol... your not running out of fuel, you have an intake leak
nobody makes a 2lb supercharger. If your only boosting 2psi, youve got problems....
ORIGINAL: tckylem
NO 2lb of Boost!!!!
360HP is good for 2LB of boost
The whole point of my post is it is running out of fuel. The reason the boost is so low is because the heads flow great thus reducing the boost pressure. I need to build a fuel system so I can crank the boost.
NO 2lb of Boost!!!!
09-16-2015 07:53 PM
09-10-2015 08:39 PM
