42lb injectors
RE: 42lb injectors
ORIGINAL: amhsraptor
you can just buy a granatelli 90mm maf, instead of getting a lightening. but the only one i could find was for 19lb so yould have to get it recalibrated. not so sure about the injectors
Also, EVERY 'calibrated' MAF is a little questionable. It is best to use Ford equipment, or a dyno/custom tune when possible...
jason
RE: 42lb injectors
ORIGINAL: AdderMk2
see, now had you mentioned that you were supercharged, it would have been a different story
ORIGINAL: mysticstang
the tuner said that i should get those before i do the tune, it has full exhaust and a vortech v-1 10 psi and a handle full other things. thanks a bunch guys.
RE: 42lb injectors
ORIGINAL: PRO50SC
Extracting info sometimes can be a painstaking operation. Adder, you should know this by now!!
ORIGINAL: AdderMk2
