1989 5.0 HO Injectors Too Big?? Causing hesitation
I have been puzzled by the way my car has been running. It is a 89 5.0HO with 160k miles. It hesitateswhen you areat constant throttlewhile in gear, not inneutral.It idles fine. Keep in mind, it doesn't always do this. I noticed when it's warmer outside, it doesn't hesitate.
It has the blue injectors, which I assume are 24lb. I am pretty sure the motor is stock. It has aBBKCAI andnoCats. still has EGR hooked up.
I also cleaned the IAC, and MAF. Recently installed new distributor, cap, rotor, wires, plugs, fuel filterand PCV. I am stumped. I have been tinkering with this for a while. I checked for vaccuum leaks, but didn't find any. My CL is not on. I also had a mechanic look at it and he didn't come up with anything.
I am thinking maybe the injectors are too big??
Thanks in advance
[IMG]local://upfiles/55399/6D9C35E94FA44C92AF09DDE2196EFAF2.jpg[/IMG]
Thanks in advance
RE: 1989 5.0 HO Injectors Too Big?? Causing hesitation
Fuel pump is not abnormally loud. I hear it turn on, but I would say its quiet. Can I check fuel pressure at the Schrader valve with a PSI gauge or do I need a certain tool.
Thanks for help
Thanks for help
