Stock motor with 24lb injectors:What tb and MAF do I need
89 Gt with stock motor andBBKCAI. I noticed it has the blue injectors(24lbs). It has the stock throttle body and stock MAF.
I am wondering if it would be beneficial for me to get a bigger TB and MAF. If so, what size/setup. Also, is it worth buying a new EGR plate? Not really planning on any drastic future mods so keep this in mind. Just want it to run better.
RE: Stock motor with 24lb injectors:What tb and MAF do I need
there is no way your running 24# injectors on a stock maf unless your computer is chipped... so it looks liek you need to pull your ECM and make sure its not chipped
The guy I got it from said it had a differentcomputer. I'm not too familiar with this, just going by thathim sayingit was the stock MAF. That's about all I know.
the previous owner may have converted to a 93 Cobra computer/maf/injectors.
check the part number on the MAS (maf sensor).
It should read 'F1ZF' or 'F1SF' or 'F2VF'
This will give us a clue...
jason
jason
ORIGINAL: Jhoward
it SHOULD be X3Z if its a cobra unit
realistically, upgrading to anything else right now would be a waste of money. The biggest intake restriction on a stock fox is the 55mm maf, which you dont have
get more mods in other places before you worry about the TB
