Do I need bigger injectors?
#21
RE: Do I need bigger injectors?
ORIGINAL: ohsoquik02
well if you got something to say then say it through pms. no need to just add to your post count for fun. did i say learn from me, no i didnt. you got an issue with me use pm. this post went off topic cause you tried to correct me
ORIGINAL: mdvaldosta
dude, wtf are you thinking telling me I should learn from you? I dont know who you are and I don't care, I glad your confident in what you know - Im happy for you. Its tough holding my tongue, lets just leave well enough alone.
#22
Listen bud, this thread did not go off topic, it is right on topic and the reason I am correcting you is because you are full of sh*t, now while I'll give you alittle credit because 80% is the "ideal" duty cycle - the "max" (which is what were talking about) safe duty cycle for most injectors is generally accepted to be 90%, and that includes every injector used on a Ford 5.0 or 4.6 engine. If I have a personal issue with you then I will pm you, but if its about this subject I certainly will post for all to see.
#23
now if im full of **** show me im wrong.
19lbs will support 300 hp. no need to go higher. if you want only go ot 24 anything higher is a waste of money
First, since your so smart Im sure you already know that Ford rates their fuel injector flow rates at 39psi. Secondly we know that were talking about 19# injectors and that a typical NA performance engine has a BSFC (brake specific fuel consumption, though Im sure you already knew that too) of .45. So lets do some math shall we?
19# x 8 injectors x .8 duty cycle / .45 = 270 hp
now lets try it my way...
19# x 8 x .9 / .45 = 304 hp
so you see, what we have here is a simple case of someone who doesn't know what the fvck their talking about (you) simply repeating two different peoples opinions on what should work ... only problem is that the two people you picked had different opinions! How and the hell can you get 300 hp out of 19# injectors with an 80% duty cycle??? You can't because the 300hp mark is achieved with the 90% duty cycle bish! Its not friggen possible to get it at 80% unless you bump the fuel pressure. So quit talking like you know better and remember when you told me this:
dude im going to warn you right now DONT AND I MEAN DONT TRY TO CORRECT ME.
#28
Well I do want to be sure everyone knows that its not a good idea to "try" for a 90% duty cycle - that around 70-80% is "ideal". The question was how much could the injectors support, as in maximum hp - therefore question of maximum duty cycle came up. I do apologize for the argument, I realized right away that this dude wanted an argument so I tried to back out of the conversation ... TWICE!!!! I tried to just leave it alone... but he kept pushing...
I woulda rather have had a healthy debate, not an argument where I'm threatened to "learn from him" ... and I wonder why he read this thread last night for an hour but didn't respond?
ORIGINAL: ohsoquik02dude
you can either learn or not
