A/C Eliminator
RE: A/C Eliminator
yea i only used the a/c like once or twice a year when its over 90, but then it broke last year, i dont know what the prob is but id rather just get rid of it.. i love driving with the windows down. But if i get the eliminator kit, is the belt i need, just the serpentine belt w/o a/c?...
RE: A/C Eliminator
Basically, If you have to just take a piece of string and wrap it around where the belt goes and measure it. If no one knows the size then thats your best bet. Ive never personally replaces mine cause its still good.
RE: A/C Eliminator
yea i've never replaced mine either but with the kit, it says i will need a shorter belt.. and they have belts that are w/ or w/o a/c for 93 mustang so i figure since i'm removing the a/c, then the belt for w/o a/c should be the right one... i just want to make sure there is no diff when having no a/c and when removing the a/c...
RE: A/C Eliminator
Man I have two of the A/C Delete kits sitting around. I've even got thebelt you need if you ditch the smog pump also. I would do both if I were you, and do it right using this kit. It relocates the power steering pump upward a little bit, and makes everything look really clean. You also get rid of about 70 lbs off the front of your car if you pull a/c and smog. That = traction.
