STARTER SLIPPING
STARTER SLIPPING
I have a 91 Lx 5.0 and when i crank it it just slips like it has a bad flywheel. i have tried 3 different starters and i checked the flywheel and it is fine. you can hear the gear go out but just not engaging all the way. is it possible for it to be bad battery cables? the car sat for a while
RE: STARTER SLIPPING
Are you positive that your flywheel has NO badly worn teeth? Also, over time, your bolt holes for your starter can wallow allowing the starter to shift slightly when it is engaging. Or you may need to shim. There are actually a few issues that could cause that. If you have a new battery and the cables are connected well and your starter is well grounded then that won't be the issue, you can eliminate that fast.
ORIGINAL: shtyd80
Sounds like the gear is spinning but its just not reaching the flywheel all the way when it is. sticky solenoid? or what, im not an expert at this stuff
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
09-08-2015 11:50 AM
