Turbo or supercharge
hey guys looking for some opinions, im looking at building a street worthy 331ci stroker that makes around 600hp with ether a supercharger or turbo?? which rought do you recomend, and what company would be a good one to go with, if i supercharge i was thinking about a procharger, what do you think
thanks
thanks
RE: Turbo or supercharge
If you're looking to make 600 HP, you're going to need to do a ton on top of a straight 331. SC or turbo, heads, cam, intake, juice, etc.
You'll need an aftermarket block as well.
I'll be making about 450 with h/c/i, SC, exhaust, 42 lb.inj., 90 MM MAF, 70 MM TB, and all the other supporting mods.
What do you already have done and what were you expecting to spend?
ya my budget is just as i go, im not in a hurry right now to get it done, as far as the engine goes i was looking at ether the new boss 302 or a dart block, forged internals, AFR 185 heads, dont know about the cam, and a trick flow intake, as of right now i havnt bought a single piece, im just trying to get as much info as i can before i start in on the project
Look into this place for heads/cam
http://www.camshaftinnovations.com/
If you're wanting to shell out the cash for a complete turbo kit I would look into Hellion. If this were my build though then I would head over to turbomustangs.com and read about piecing together my own turbo kit.
I bought my heads and cam from Camshaft Innovations, but I'd recommend doing it yourself. Get some AFR heads and call comp cams directly, explain to them what you want and they can grind one for you. Think about it, Camshaft Innovations does may be a few hundred custom cams a year, while comp cams does thousands.
I'm pretty sure my cam is a comp, just made to Jay Allen's spec. You can cut out the middle man.
ya that was my idea, to try and put together my own turbo kit, just because i think it would be really rewarding if it worked well to know that i did it. Thanks for all the help, is there any other websites that you would recomend looking at for putting together a turbo system??
