TFS Stage 1 vs. FMS B303
ORIGINAL: AdderMk2
Steeda #19 with 1.7 rockers
.510/.510 and 220°/226° duration @ .050 lift
I would probably be more inclined to go with the Trickflow, but people still make good power with the B cam.
ORIGINAL: 87black snake
what other mods do you have?
If your on atight budget (arent we all) and canbuy a used B303 cheap ( $110.00 or less) then go for it, provided the cams in good working condition.The difference in performance between the TFS cam and the B 303 cam wont be that much different in your case. You can take the money you save and put it towards those GT 40 heads or some 1.7 roller rockers which should even up the cams alittle.
what you need to look at is the specs on your stock heads. they can barely support steeda and tfs. the fms cam is still under the limitations of the stock head. i had a previous thread where this was explained to me. if you got with the other cams you should replace head/ springs to allow for more lift. actually even with the b303 cam from fms you need to upgrade them but you can at least get away with stock for a while. i'll post it if i can find the thread
also i had a spec card that came with the cam from fms, it has a longer duration. the guy that did my engine said its more efficient than the other cams...he recomended it to me so i bought it...i love it so far
jwog666
Dec 27, 2021 08:09 PM
junior04
Sep 28, 2015 10:53 AM
Sep 25, 2015 09:06 AM
