5 lug conversion advantages?
Old Feb 15, 2007 | 01:22 AM
ebk06's Avatar
ebk06
Default 5 lug conversion advantages?
Besides having a wider selection of wheel is there any real advantage to converting to 5 lugs?
Old Feb 15, 2007 | 01:23 AM
PJB's Avatar
PJB
Default RE: 5 lug conversion advantages?
Much better brakes.
Old Feb 15, 2007 | 01:31 AM
immr.mustang's Avatar
immr.mustang
5 studs to beak if you have enough h.p. instead of 4...........................
ebk06's Avatar
ebk06
ahhhh yea i guess thats pretty important.
Old Feb 15, 2007 | 11:15 AM
dimebag's Avatar
dimebag
yea now someone tell him how much hp were talkin... cuz im not seein breaking wheel studs w. the amount of power the majority of mustangs put out.....
personally, im stayin 4 lug... might go to 31 spline axles if i need to one day, but not gonna bother w. 5 lug...
Old Feb 15, 2007 | 11:37 AM
PJB's Avatar
PJB
I really dont see how 4 lugs are stronger than 5. If youre snapping lugs for some reason having one more really wont make a difference.
Im just doing my swap for better brakes and not to have more studs or different wheels.
Old Feb 15, 2007 | 11:42 AM
MadMan@TheWheel's Avatar
MadMan@TheWheel
Better wheel selections, basically if you are breaking wheel studs you damn sure should not be driving on the street. They make disk brakes for 4 lugs also, so that is really not all that big of a deal. I don't know if I have ever actually seen a Mustang break a wheel stud.
Old Feb 15, 2007 | 11:52 AM
88BlueGT's Avatar
88BlueGT
+1 There are alot of companies who make brake kits for 4 lug (baer, etc). Idont plan on swapping rims every summer or anything and they make the rims I want in 4 lug so I think thats what Im sticking with. Plus, if you convert to 5lug with a kit or something its like 2G's (of coarse for a nice cobra kit or something) but than you need to buy new wheels right then too because the stockers will no longer work. Than if you are replacing your rim from a stock rim you will need new tires. You easily spend 3K+ on a rim/tires/5 lug conversion... F*CK THAT!
Old Feb 15, 2007 | 12:06 PM
93must's Avatar
93must
Your going to spend over 2k on a good bear brake set up for 4-lug too! So if your going to go with a good brake set up you may as well go with the 5-lug, if you want more wheel options! JMO
ORIGINAL: 88BlueGT
Old Feb 15, 2007 | 12:07 PM
88BlueGT's Avatar
88BlueGT
Ehhhhhhhhhh .................................. Yea, your kinda right... I guess..... I dunno... I think Im gonna run stock brakes for ever!
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Oct 7, 2015 07:02 PM
Dragonus18
Sep 9, 2015 01:21 AM
