Fox rear disc conversion WITHOUT a master cylinder upgrade? okay??
Hey guys, has anyone had any expierence with putting rear discs onto thier fox Mustang without upgrading that master cylinder to a larger bore?? Thanks a lot guys cya
RE: Fox rear disc conversion WITHOUT a master cylinder upgrade? okay??
You are doing a brake upgrade.......why wouldn't you want to UPGRADE THE MASTER CYLINDER? DUH YES!!!!!! Remember with rears discs you will be pushing more fluid. I got the Cobra Master Cylinder, when I did mine.
yes i plan on upgrading the master cylinder as soon as possible. but until i can get one/find one/get one shipped do you think it would be ok to drive? or will it be WAY too much pedal travel? thats wht im asking
ORIGINAL: rppngears91
pick up a 1984-1986 mustang svo master or a 1983-1992 lincoln mark 7 master and also upgrade to the svo/lincoln calipers in the front
or u can use the sn95 but if u get one from the parts store it doesnt come with a res.
Someone please correct me if I'm wrong, but a '93 Cobra master should bolt right up and is for 4 wheel discs.
It's also $89 *new* (not a remanufactured) at Advamce Auto with no core charge.
