stroker
Old Feb 18, 2007 | 10:06 PM
Goosepoop302's Avatar
Goosepoop302
Default stroker
So ive been looking around and i see these stroker kits there selling online. well i dont know exactly a ton about them so if anyone knows what would all be needed if i decide to get one?? there is one for roughly 1300 $ that is a 347 but i dont even know what would be best with my mods.....i need help haha
Old Feb 18, 2007 | 10:27 PM
LTnone's Avatar
LTnone
Default RE: stroker
He's back from the dead! Get that thing running right? How is it?
Old Feb 18, 2007 | 10:41 PM
w8less's Avatar
w8less
Default RE: stroker
what does it come with
Old Feb 18, 2007 | 10:49 PM
Goosepoop302
Default RE: stroker
it would be running well accpet for 2 things. the clutch (jsut needs to be installed) and there is a leak from a header bolt somewhere. o eah need a tune bad! but otherwise yeah its cool. ill link one of the kits http://www.fordstrokers.com/index.ph...category_id=55 of i do decide to stroke my stang ......yea i said it.... what is the best for what i currently have
Old Feb 18, 2007 | 11:17 PM
fordstroker's Avatar
fordstroker
I ♥ Acer
Default RE: stroker
Im the owner, ask away
Old Feb 18, 2007 | 11:26 PM
Goosepoop302
Default RE: stroker
well as of now i have heads cam intake and so on with the supporting mods. the heads are trickflow twisted wedge heads and street heat manifolds. what would be a good stroker kit to run on that with the occasional nitrous maybe SC in the future?? what else would i need besides one of those kits?
Old Feb 18, 2007 | 11:32 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: stroker
i would shoot full auto a PM. he always has great deals
fordstroker
I ♥ Acer
Default RE: stroker
Personally I would be running a 347 street fighter, cast steel crank kit. No need for a steel crank in a stock block. Pistons are cut for either tfs or inline heads. You will have to notch the bottom of the cylinder, make sure there is .060-.070 thou clearance between the rod bolt and the bottom of the cylinder. Have it balanced like any rotating assembly, build it like any other 302, make 400-450 N/A depending on tune and final combination
Old Feb 18, 2007 | 11:36 PM
Goosepoop302
Default RE: stroker
i was looking at the 347 kit is the PRO really any better??? also how much am i looking at for the extra work (notch, any install i cant do) what kinda times does that produce
Old Feb 18, 2007 | 11:41 PM
fordstroker
I ♥ Acer
Default RE: stroker
ORIGINAL: Goosepoop302
The pro street kits consist of an H beam or lightweight I beam rod and forged steel crank, they are used when NOT using a stock block. A stock block does not care if it takes a 40 dollar replacement stock crank or a 2000 dollar bryant billet crank. 90% of my guys notch the block at home with a dremel, its simple. As for times, et's? I couldnt begin to tell you unless you gave me a luandry list about your car, and then its still vague. PLENTY of guys have gone mid 11's with a full car weighing 3000+ lbs. Hell you can get a 3000lb mustang to go low 12's with 300hp at the crank if you know what your doing.
