Can I upgrade my heads?
RE: Can I upgrade my heads?
ORIGINAL: Twisted
I don't think I want to go to the trouble. If I were gonna do the cam too, I'd be tempted to have the work done instead of doing it myself. I'd love a cam, but really don't want to commit that kind of time to swapping one in. So you'd do the heads if you were in my situation?
ORIGINAL: mustnglvr
I always feel good about upgrading heads, what about a cam?
As for the heads themselves. From what I gather, theyre just ported E7's. True porting will make them better, but why not buy some GT-40's or '69/'70 351W heads? Your net HP gain will much more than the E7's and they'll still appear to be factory heads.
-P.
Thanks for the info, fellas. Alright, I guess I'll do the cam when I do the heads then...if it's not that much more work. I was looking at Thumpers because the price is right, and it sounds like the heads perform well. If I were to get GT40s or others used heads, I'd have to shell out to have them freshened/ported. Don't get me wrong though, I'm open to suggestionsin the price range of the Thumpers.
Twisted if you compression is 165 in all the cylinders or around there, that is really good. That means your motor is almost new. When I installed my heads my compression was 143 lowest and 150 highest. Had them on a little over a month, checked the compression the other day and it hasnt went down at all.
ORIGINAL: P Zero
[1, swappin heads out is WAY more involved than just changing a cam. Theres not much more that you would really have to do. Simply remove some of the accessories from the front of the motor, pull the crank pulley and timing cover, youre there. Its maybe an additional hour worth of work.
Im thinking you need to do that to slide the cam out due to the length but I could be wrong.
ORIGINAL: 94ford5liter
ORIGINAL: BlackLX
Do you have any plans for the intake? Since you're going with thumper I would look into having tmoss port your stock intake.
