Starter Problems.....
Old Feb 22, 2007 | 01:30 AM
89 fox's Avatar
89 fox
Default Starter Problems.....
i just installed my new mini starter from a 93 on my 89. i think i have it hooked up right. i ran 2 new wires....a 4ga to replace the OEM wire and a 12ga to run the extra wire it takes to make the new starter work. i ran the 4ga from the post furthest from the battery on the firewall solenoid to the large post on the new solenoid on the starter. i ran the 12ga wire from the post closest to the battery on the firewall solenoid to the small post on the solenoid on the starter. when i try to turn it over...all i can hear is the firewall solenoid clicking.....any ideas on how to fix this headache???? thanks!
Old Feb 22, 2007 | 10:16 AM
89 fox's Avatar
89 fox
Default RE: Starter Problems.....
bump
Old Feb 22, 2007 | 10:34 AM
grabbem88's Avatar
grabbem88
they tight?...run a jumper wire to the hot side then go from there...
Old Feb 22, 2007 | 10:58 AM
tjmon1's Avatar
tjmon1
That sounds like it has bad continuity. Just like grabbem88 said, make sure the connections are tight. Did you put conductive jelly on them?
Old Feb 22, 2007 | 11:12 AM
89 fox's Avatar
89 fox
ORIGINAL: grabbem88
should i jump thefirewall solenoid or the one on the new starter? also...does it sound like it is hooked up right? i went off the diagram, but it doesn't give the greatest explainination on where the 4ga wire goes..
Old Feb 22, 2007 | 03:14 PM
89 fox's Avatar
89 fox
bump
Old Feb 22, 2007 | 08:10 PM
5ohfox's Avatar
5ohfox
IM HAVING THE SAME PROBLEM. ON MINE, BUT I CAN ONLY SEE ONE WIRE GOING FROM THE STARTER TO THE POST NEXT TO THE STARTER RELAY. AND WHEN I TURN THE KEY ON. ALL THE GAUGES LIGHT UP, BUT ITS NOT TURNING OVER?
Old Feb 22, 2007 | 08:12 PM
mattdel's Avatar
mattdel
blakesnake are you saying that the new starter has its own solenoid? if that is the case, you don't need the stock firewall solenoid.
Old Feb 22, 2007 | 08:47 PM
89 fox's Avatar
89 fox
it does have a solenoid built on the new starter. how would i bypass the firewall solenoid?
Old Feb 22, 2007 | 08:49 PM
mattdel's Avatar
mattdel
can you take a picture of the new starter's solenoid? should have 2 large posts, and 1 small terminal.
1 of the large posts might have its own ground strap on it.
