timing chain
timing chain
ok guys, I think Im gonna buy a small project car.
The car needs a new timing chain. I've never had to do this before, so how hard is it and how much time should I allow for the project? I'm decently mechanically inclined.
Let me know fellas.
Let me know fellas.
RE: timing chain
I found a good write up...however...
what all do I need to order from Summit? Obviously a timing chain/gear kit, gaskets, and bolts but is there anything else that I have to buy???
Let me know ASAP so I can get this stuff ordered!!!
RE: timing chain
ORIGINAL: mattdel
scale of 1-10, timing chains on this motor are about a 6. should take about 1 1/2 hours with hand tools.
Get some RTV ultra black silicone sealer.
RE: timing chain
yeah all ya need to do is take off belts pulleys,and timing chain housing make sure ya cam sproket,and crank are lined up right...theres a dot on each one.... #1 piston is up,and the dots line up...cam sprocket dot at 6 o clock,and crank at 12 high noon...
RE: timing chain
Matt, I'd like to see that one.
RE: timing chain
yeah Im planning on dedicating an entire day to the project just to play it safe.
Can I just make sure that the timing chain goes back on the EXACT way it comes off? Will there be anything wrong with using this method?
thanks for everything fellas
