what cam should I buy?
For my stock motor gt??
I was looking at the crane energizer cams.... which 1 should I buy?? How much will an install run me?? How much will a tune run me and can I run without a tune for a while(will this hurt performance by not tuning it?).. I am planning on getting a cobra upper/lower mani as soon as I install the camshaft
I was looking at these.. which one should I get that will be the best for the street and not have problems with it?
http://www.jegs.com/webapp/wcs/store...44648_-1_10707
I was about to buy this one, but thought I would ask you guys if I should do it first.
Energizer Hydraulic Flat Tappet Camshaft & Lifter Kit
Lift: .498'/.498'
Duration: 278°/278°
RPM Range: 2200-5600
Lift: .498'/.498'
Duration: 278°/278°
RE: what cam should I buy?
That would be a good size cam to put in your motor, but I must say that it is not really worth installing a cam unless your changing out the heads, at least some GT40s or somethin.
ORIGINAL: 94ford5liter
I know it would be best to install heads at the same time as cams, but when I have enough for heads I'll just upgrade the cam
How much will this cam help my mid and topend??? My topend SUCKS right now
