Water pump leakin
Water pump leakin
ok so i got home today and my water pump was leaking profuesly out the bottom of it. The pump was replaced just before i bought the car. Is therea gasket thats leaking or is the seal in it bad? What should I do? BUy a new pump and put it on?
RE: Water pump leakin
whats that? haha I dont think its out of the weep hole, its leakin ALOT. I over heated the car once so i thought maybe the shaft seal went out cuz of that but that was like last october that happend so I dont think 5 months later the seal went out because it was over heated. I am going to the NHRA nationals tommrow morning so we are takin the wifes car, but before we go i am going to start it up and let it run to see if i can tell where its really leakin from. I didn't see a weep hole on this pump, i just saw it leaking out of the bottom where the gasket is.
ugh, if you overheated the car more then likely you need a new pump, when I got my 5.0 the pump wasthe original ford one, and had the tell-tale signs of leaking through the lil' weep hole
ORIGINAL: 86 5.0L
