Will this work? 351 plus some goodies
Old 02-25-2007, 10:08 AM
LesteR723
LesteR723's Avatar
Default Will this work? 351 plus some goodies
okay for now, im just going to get a rebuilt 351 with camshaft, lifters, pushrods, oil pump, pistons, piston rings, connecting rod bearings, main bearings, cam bearings, timing chain and timing gears, reconditioned cylinder heads with new valves and gaskets on ebay for like $1,600, throw on an intake and some front end goodies and get a new trans, clutch pressure plate, flywheel, driveshaft etc just so i can get my car running. when i get the money... here is what i want to do:
i want to get the block bored out to a 408 and put in forged internals, strap on some AFR 185 heads, a more agressive cam, a GT-40 lower intake manifold, and a KB top mount supercharger. will the block be able to hold up? they build the blocks to "manufacturer specs". also what boost level would i be able to run it at? the blowzilla can be run at 6, 8, 10, 12, 14, 16, and 18lbs.
thank ya guys.
LesteR723 is offline
Old 02-25-2007, 10:12 AM
90lxupgrade
90lxupgrade's Avatar
Default RE: Will this work? 351 plus some goodies
i am getting ready for my 351 swap into my 90lx and do you know what parts are interchageable
also putting a c6 trans in it
90lxupgrade is offline
Old 02-25-2007, 10:33 AM
AdderMk2
Banned
AdderMk2's Avatar
I'd say save the money and dont buy the remanufactured block. You can buy a SCAT stroker kit for $1200 and poke it out to 393, just find a bare block somewhere, or even if someone is selling a long block, and have it cleaned and machined.
check out www.craigslist.com for some great deals. I found my RUNNING complete, carb to pan 351w with C4 trans for $350
AdderMk2 is offline
Old 02-25-2007, 12:06 PM
bds95stang
bds95stang's Avatar
i got a running complete 351 for free
bds95stang is offline
Old 02-25-2007, 12:13 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: bds95stang
ditch the cam and the heads, and youll get some good power out of it
AdderMk2 is offline
Old 02-25-2007, 11:56 PM
LesteR723
LesteR723's Avatar
i'll look around but i want a roller block for sure... so i dont know if im gonna find one of those by the time i need it so i may just go with the reman. one.
as for boost... what do you think i could/should run if i'm goin with forged crank pistons and rods on a 408 roller block?
Old 02-26-2007, 12:06 AM
Yngvar
Yngvar's Avatar
can I get a 351 with fuel injection to fit under a stock hood or how high do I have to go get it to fit? but I want a stock look with out the big cow hood or will a super mach work.
Yngvar is offline
Old 02-26-2007, 12:10 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: Yngvar
1.5"-2.5" will work... its possible to get ti to fit, just unlikely
LesteR723, you dont NEED a roller block, and the older the block is, the better. 70's blocks have a higher nickel content and will handle more power. You can also EASILY retrofit a old block with roller lifters by using the linked lifters.
AdderMk2 is offline
Old 02-26-2007, 12:15 AM
ih8chevy
ih8chevy's Avatar
+1. they are jsut liek the older 302's can hold way more power than a newer 5.0. the roller conversion is worth it butu dont need it, those flat tappet motors will make awesome power when built right.
ORIGINAL: AdderMk2
ORIGINAL: Yngvar
ih8chevy is offline
Old 02-26-2007, 03:47 AM
vristang
vristang's Avatar
Lester,
I cleared the stock hood on my 90GT by doing the following...
Lightning lower intake.
Comp cams box upper intake
'captured' convertible style motor mounts.
I also had to trim about .700" off the lower surface of the upper intake manifold.
It is a nice feeling to get a 408w under the stock hood
The roller stuff will come down to what you want to do, and expect to pay.
I have some more details on the swap here...
http://www.freewebs.com/vristang/fox351wswapfaq.htm
vristang is offline
Quick Reply: Will this work? 351 plus some goodies
