crack all your bleeder screws front and back...then let gravity bleed all four lines. Make sure you keep topping up the master cylinder always keep it full....you have to have a lot of air in your system.
if you re-used the old copper rings from your old lines, your letting air back in.
Not true. I can't tell you how many calipers I have installed over the years and re-used the brass/copper o-rings. As a matter of fact, the reason I don't is b/c when I first started doing this way back when, the new o-rings failed so I never changed them since and NEVER has there been a problem.
