Gaskets seals and what no for H/C/I swap
RE: Gaskets seals and what no for H/C/I swap
ORIGINAL: OnyxCobra
you may want to look into stiffer valve springs, hardened pushrods, and lifters...
no i just ship the lower and he heads of to thumper he ports and polishes the heads and does a 5 angle valve job and ports the lower to match and starting and sends them bak with a cam and timing gears and chain... then i need to put everything bak on... im doing the swap... there just doing the head work and puttin the heads bak together
he is puttin all ne parts into the heads... so if the pushrods are located in the head then they will be replaced... i havent heard of thumpers heads having in problems with them so im not to worried about what his goin to do... i jus dunno what i need to do installation wish... thumper is pretty well know... i dont think he would put stiffer springs in if it would tear up something else...
ORIGINAL: 92hatchLX
Just get the complete ford racingengine gasket set off of Summit.
