Water temp sensor problem!
Ok, so my car was running a little hot after swapping out electric fans, possibly need to burp the system. I decided to lose the factory Volvo temp sensor in favor of a standard triple set of Sunpro gauges.
I removed the electric temp sensor from the lower manifold, then tried to screw the new probe in . No, doest fit. It looked like there was some thread adapter. I started to unscrew the adapter and…. *TING!*… friggin head snapped off. Being brass, it didn’t take much. So, here I am trying to remove this helicoil of sorts. I cant get the damn thing out, and even if I do, I don’t understand how the probe is going to fit snugly in the hole because when I thread in the fitting, what’s to keep the probe from falling through? I don’t see where it’s going to seat the probe, so what keeps it tight?
93 LX FiveO, I should have mentioned that, the brass fitting is stripped completely. I've got to get the brass part outa there. None the less, I still dont understand what is to keep the probe from falling through once I do get the fitting to thread into intake.
aode06, why are you suggesting I swap intakes? I dont think I've screwed up that bad.... (I dont think)...
ORIGINAL: 93 LX FiveO
get an autometer sending unit
it will just thread right in
TfcCDR
Sep 14, 2015 12:08 PM
