Priming a Fox
Old Feb 25, 2007 | 08:06 PM
fugazi89gt's Avatar
fugazi89gt
Default Priming a Fox
Hello,
I have an 89 Fox GT... And I want to prime the body.... I want to know if I can do this myself or if a shop has to do it... If I can do it, what are the steps required to do a good job...
By the way, the car is painted right now, So do I need to sand the existing paint.... Please let me know.
Old Feb 25, 2007 | 08:14 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Priming a Fox
1st step wash the car then wipe it down with silicone wax and grease remover. tape up all the trim so u dont ruin it scuff it up with some 320 or 400 grit paper blow it off wipe it down with wax and grease remover again then tack it off then prime thats it in a simplified nutshell
but remember that primer absorbs water so anywhere u go bare will have surface rust in short order an epoxy primer shoule be used over top of a surfacing primer if u plan on keep it that way for a while to hold off on the rust
Old Feb 25, 2007 | 09:27 PM
PJB's Avatar
PJB
You dont need to prime the whole car, just the repair areas need primer.
For areas that are ok just wetsand them down with 1000 grit sandpaper before painting. Basically that just takes off the clearcoat.
jwog666
Dec 27, 2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
tramphardrocker
Sep 13, 2015 08:56 PM
