Here we go again
Old Feb 28, 2007 | 08:47 PM
89gfoxlx's Avatar
89gfoxlx
Default Here we go again
In regards to the 90 gt in my sig. I am trying to figure out what kind of h.p I have at the tires, and also if i should go to 3.73's or 4.10's. Also can anyone give me about what my 1/4 mile time should be? thanks alot
89gfoxlx's Avatar
89gfoxlx
Default RE: Here we go again
oh yeah its also a 5 speed
Old Feb 28, 2007 | 08:49 PM
5.0stanger's Avatar
5.0stanger
I would guess amid to lower 14in the 1/4 (if you can drive and hook) and around 220ish to the wheels
Old Feb 28, 2007 | 08:51 PM
5.0stanger's Avatar
5.0stanger
I would also run a 3.73 gear with the 5 speed.
Old Feb 28, 2007 | 11:38 PM
89gfoxlx's Avatar
89gfoxlx
also what would be a good h/c/i setup for what i have that would make the most power because i wanna try and stay n/a
Old Feb 28, 2007 | 11:47 PM
Ninety5five0's Avatar
Ninety5five0
^ thats a pretty open ended question. There are lots of good HCI combos you can go with, thousands of possibilities. What are you lookin to get out of the car ? Street or track ? Whats your budget ?
Old Feb 28, 2007 | 11:51 PM
89gfoxlx's Avatar
89gfoxlx
It will be alot of street, not a dd, but a little bit of track time. budget pretty slim
Old Feb 28, 2007 | 11:54 PM
stangman94's Avatar
stangman94
for heads you can go with afr's 165 trickflows edelbrock etc. the manifold since its a street car I would say the street heat manifold or bore out your cobra . Go with 3.73's if its a stick
Old Feb 28, 2007 | 11:58 PM
89gfoxlx's Avatar
89gfoxlx
which heads would be best to for higher compression now and then later would have the ability to be ported for a s/c if i decide to go that route? also what injectors and maf sensor size?
Old Mar 1, 2007 | 02:16 PM
ttoppedaerocoupe's Avatar
ttoppedaerocoupe
ORIGINAL: 89gfoxlx
front or rear tires, can you be a little more specific please?
Take your car to a dyno, then a track. Do a search about gears, and read through any of the eleventy billion threads.
problems solved.
