Header Issues! help
Old Mar 2, 2007 | 10:18 PM
N8_FIVE.O's Avatar
N8_FIVE.O
Default Header Issues! help
I am installing MAC shorties and the holes for the bolts are not lining up with the motor... We are talking millimeters but at any rate not lining up. I can put in 1 bolt and that is it.. Has any body had this issue before? What did you do to resolve? Does anyone have any suggestions? Should I just bend the darn things? Should I drill out the holes on the headers slightly bigger to compensate... I am fairly certain these are the correct ones for my 88GT... Beyond frustrated!!!
Old Mar 2, 2007 | 10:22 PM
w8less's Avatar
w8less
Default RE: Header Issues! help
with my odl lt's if u didn't start from the back and work ur way forward they wouldn't line up for nothing either.
remembers HEADERS ARE A BEOTCH
Old Mar 2, 2007 | 10:33 PM
N8_FIVE.O's Avatar
N8_FIVE.O
I did start from back forward... I guess maybe I need to know if this is normal.. if so then I am fine I guess and can deal.cope however if this is uncomon then I need to know if I should send back or what can be done to resolve.. I suppose I could just bend them. What would you do?
Old Mar 2, 2007 | 10:47 PM
N8_FIVE.O's Avatar
N8_FIVE.O
ok.. I pulled the header back off and matched it up to the gasket and the hole (back to front) back lines up but it gradually gets further and further off. but the time you get to the 8th hole (very first) it is off by at least 1/8 of and inch,.. Is this normal? Should I bore the holes out?
Old Mar 2, 2007 | 10:56 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Get better headers. This is a common problem w/ flangeless headers.
BBK, w/ connecting flanges!!
Big difference
Old Mar 2, 2007 | 10:59 PM
PONY GUY's Avatar
PONY GUY
leave everything loose on the exhuast and looesenthe motor mounts also it helps lining it up a bit
Old Mar 2, 2007 | 11:37 PM
89 fox's Avatar
89 fox
how does that help???
Old Mar 2, 2007 | 11:41 PM
stocksuspension's Avatar
stocksuspension
thats were the matco 42 inch pry bar comes in to play
Old Mar 2, 2007 | 11:42 PM
PONY GUY's Avatar
PONY GUY
I makes lining everything up easier then once is all together you can tighen everything down
Old Mar 2, 2007 | 11:46 PM
grabbem88's Avatar
grabbem88
macs suck..yes you will have flex them....alot
