Throttle Response
Old Mar 4, 2007 | 10:37 PM
93stallion302's Avatar
93stallion302
Default Throttle Response
ok wat do i need 2 do 2 give my car better throttle reponse. I hate that time lapse from wen i step on the gas till it reponds. even wen im at a good rpm.
Old Mar 4, 2007 | 10:40 PM
AlabamaCobra's Avatar
AlabamaCobra
Default RE: Throttle Response
eh i bought an 89 like that (speed density) and me and my dad changed distributor cap and rotor button, spark plugs,air filter, and basically a tune up and it helped it a good bit. BTW spray the hell out of your throttle linkage and the gas pedal with WD-40. hope it helps
goathead75's Avatar
goathead75
One thing I did to my stang that made a huge difference before I put her away for the winter was changing the cap, rotor, wires, plugs, and adjust the TPS to .99v. WOW, big big difference. The throttle was real snappy after that.
When was the last time you did a tune up?
Old Mar 4, 2007 | 10:50 PM
93stallion302
not too long ago bout 3000 miles ago im due for another. imma spray my linkage ive never done that.
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
After a tune up...try bending the gas pedal up a bit, sorta give it a better, snappierfeel
Old Mar 4, 2007 | 10:51 PM
goathead75's Avatar
goathead75
Have you adjusted the voltage on the TPS? Also, is the throttle response just delayed or is it bogging down and then taking off?
AlabamaCobra
ORIGINAL: goathead75
what is TPS???
Old Mar 4, 2007 | 10:53 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
ORIGINAL: AlabamaCobra
what is TPS???
throttle position sensor....its on the throttle body
Old Mar 4, 2007 | 11:01 PM
93stallion302
na it doesnt bog down at all it just delayed.
Old Mar 5, 2007 | 04:54 AM
vt89gtvert's Avatar
vt89gtvert
Did someone change it over to a speed density, cuz otherwise it was an MAF
The TPS adjustment made a big difference on my car. As well you might want to look into getting a better coil, or an entire ignition system if you have the money, that will help out alot as well. Cleaning the injectors might help as well (Don't know for a fact but I would think it would help out).
