cams
well what he meant was that if u dont replace the timing chain that u can do it but it will die soon once the motor is together u will have to take it apart again. if u got the money to do all that then a new timing gear and chain is no prob, get a kit a cam kit it comes wit springs timing chain and gear, seats, etc. from comp cams. the xe294h is a kit i suggest u check out.
not the best idea either. unless they are relatively new
ORIGINAL: 94StinkinLincoln
all i need is the pushrods, timing chain set, lube, and rockers...im reusing my hydraulic rollers and my heads are pre assembled.
junior04
Sep 28, 2015 10:53 AM
