tranny problems!
RE: tranny problems!
i was just going to say that, at first it sounded like a clutch or syncro but the more indepth he goes with the problem the more it sounds like a bent fork
ORIGINAL: AdderMk2
sounds like you have a shifter fork problem... time to drop the trans and look for bent internals
ORIGINAL: 94gtcoupe
ORIGINAL: AdderMk2
its gonna take some work...remove trans... open up the trans... know what your looking at so you can tell if somethings ****ed up ... remove/replace damaged parts, hope you can put it back together right... its not an easy task...
how much mech know how do you have?
ORIGINAL: dimebag
i had the same problem, it may not be your clutch or you tranny your floor mat might be pushed up behind the petal i couldnt find the problem on mine and it was just that the whole time. i felt like such a retard
