Help with 5 Lug Conversion on 89 hatch
#31
RE: Help with 5 Lug Conversion on 89 hatch
ORIGINAL: PJB
The '94+ axles are wider than the fox axles.
#32
You will need to use the rear discs if you use the Mustang axles because the drum will stick out too far from the backing plate and shoes.
Its only a fraction of an inch difference on each side (maybe 3/4?) If you figure out the right backspacing the wheels will fit ok.
#34
Youre welcome. Ive just learned this stuff by reading other topics on this subject on this forum.
Im waiting for a few warm days or a warm garage to do my 5 lug swap. I hate walking thru my garage seeing all the parts sitting there and not being able to put them on because its so cold (-5* now).
#35
Update. I have a salvage yard pulling me spindles, hubs, calipers, and the rubber brake lines for $75.00 a side. I will be picking them up tomorrow.
3Questions--First I know it does not matter if the spindles come from a v6 or a gt, but is there a difference in the calipers between the two?
Also can 13 inch rotors be installed using the stock style caliper, or do I need cobra style calipers to work with the rotors?
I know the gt has 11 inch rotors stock, what does the v6 have? I do plan on at least buying new rotors regardless if they come from the salvage yard, but I don't know what size to buy if I can reuse the salvaged calipers.
I can't wait to get started, thanks for the help in advance
#36
One more thought, if I need calipers and obviously rotors, is there Any reason I can't buy cobra 13" calipers and rotors instead of the 11"? As long as my wheels are big enough they should bolt up?
#38
ORIGINAL: kcsoa22
Mine are off a '94 v6.
Im not sure about the 13" rotors because Im only using the stock size ones.
#39
ORIGINAL: kcsoa22
