Intake manifolds
Intake manifolds
Im lookin into doing my upper and lower intake manifold im was wandering wat is the best on a budget i was lookin at the bbk ssi but i cant seem to find any reviews about it every web site says the same thing i could use alittle help trying to find the best one let me kno the hosepower changes and 1/4 mile changes
RE: Intake manifolds
Some people say that they are unhappy with the BBK SSI intake. I just baught an Edelbrock Performer RPM 2 upper and lower. And both the Trick flows that Scout2232 mentioned are both really good too.
i just bought the car for 1000 right now i have a stock motor i just bought my full rear 4.10 posi i just orderd my long tube headers and x pipe so i looking for sumtin that will be good for the long run
Either of those TrickFlow intakes or the Edelbrock RPM2 would be good for you then. You probably won't see a huge gain with just slappin' your new intake on there, but if you added new heads and a cam to the mix you can really start pushing some nice numbers. FRPP, Holley, TrickFlow and Edelbrockall sell top end packages that replace heads intake and cam along with some other things. I don't know how much money you have to spend or how patient you are for that though, all those run around $2000+.
I also agree with that with the whole H/C/I swap. The only reason i didn't get the cam and heads is because im just going to get a 331 stroker, and do heads and cam then. Plus i also figure you can't really hurt the intake just cause your making air flow better through there.
