Who knows their stuff?
ok lets see who can guess the best[sm=hail.gif]
i am about to put this motor together and im gonna bring her to the track to see what she can do.
95 GT
331 Stroker
Edelbrock Performer RPM 2 Manifolds
Edelbrock RPM Heads 2.02 intake valves, 60cc chamber, 170cc intake
Fenderwell intake
70mm Throttle Body
75mm Pro-M MAF
Comp Cam Grind # FW XE270HR-14 (1800-5800rpm)
BBK Shory Equal Lengths
FR Aluminum Drive Shaft
Subframe Connectors
Street Tires
AODE able to hold 450hp
approx 2500stall
What Fly Wheel Numbers do you think this will make?
And what do you think it will run in the 1/4?
[IMG]local://upfiles/55941/55CD52A389434A13B1806AA9CE005BCA.jpg[/IMG]
95 GT
331 Stroker
Fenderwell intake
70mm Throttle Body
75mm Pro-M MAF
Subframe Connectors
Street Tires
approx 2500stall
RE: Who knows their stuff?
I clicked the wrong one. I clicked 425+, I meant 400-425. With an agressive tune thats where id put it. Mid-High Twelves is what id say on streets. More suspension and slicks and mid elevens.
well ill put it this way...i made my 94 Lincoln Towncar:
that weighs 5482lbs, 4.6L rebuilt with 75,000miles, street tires (pretty much bald ) and its stock everything run a 16.1 in the 1/4.
eddy heads don't flow very well compared to most...i had those exact heads once..my car barely seen 13's with them...afr 185's and a smaller comp cam i was in the 12's<very high 12's....same heads but milled and springs upgraded,but with a C.I. cam i was hitting botoom 12's and seen an 11.91 at 112mph....only cause i was still using a stock tune...now with this p.m.s i'm hoping for mid 11's and with a 200 shot a 9.99 at 145mph
