Which control arms should I go with?
RE: Which control arms should I go with?
http://chassisengineering.com/shopDe...;ProductId=845
heres a complete kit, comes with everything...
For what you have described, these will work fine
http://blueovalindustries.bluekeyinc...ts.php?pid=614
Well , I've decided to go w/ HPM Mega jr's Lowers because of the fact that eventually a turbo is coming so with the mega'd you can choose two options for traction, the top hole for 85% traction above stock and after the turbo I can go to the lower adjustment for 135% more traction than stock. So with these arms I'm gonna need to adjust the pinion angle, So for the uppers I went w/ Steeda Double Adjustables with poly Bushings to help maintain some ride quaility. I didn't go with hpm uppers because of the price, the steeda's look exactly the same and come w/ bushings for the axle. Mustangs didnt come from the factory w/ a rear end setup for optimal traction, hopefully this will get me there, THANKS TO ALL THAT VOTED AND RESPONDED! I will post pictures after all said and done.
breaking
10-02-2015 01:27 PM
