what do u think about my new set up?
#52
RE: what do u think about my new set up?
two things one my car is pedestal mount,and two my intake won't pull that high..
stud 7/16's and jay's springs he can design to your desires....fast88 can help you with that..since he's revving to almost 9k
#53
Deck that block to 0, match everything not to go over 10.5 (a dished piston should do), do a good valve train setup (not pedestals please).....and Jay should take care of the cam requirements once you configure intake (single plane and 750 cfm DP minimum).........
#54
that's why i explained to jasper my situation joel.....studs all the way dude!
i had my motor together way before i talked to jay,and three cams earlier....i'm happy with my set-up thus far...hell a streetable 11 sec for what i have i can't complain
#58
What you are doing when you are 'running the valves' on a solid lifter/solid roller motor is checking that things haven't moved. IME, 98% of the time nothing has either.
With the solid stuff you have a tunability that you can't have with a hydro-roller.
You can actually play with the duration a little bit by opening or closing the lash.
