Tech Help Needed
RE: Tech Help Needed
ORIGINAL: LTnone
Whether you can use the blower is dependent on the application. What years was it designed to fit, and what year is your car? Stock comp. was 9.25:1, I wouldn't boost anything higher than that without some o-ringed heads or cometic gaskets.
From what I've read the E7 chamber volume varied between 60.6 and 63.6. Personally, if I were putting a power adder on my motor I'd count on the highest compression ratio variances would allow.
nobody even mentioned the fact that since the motor is rebuilt who knows what kinda pistons it has. if it was an OEM spec rebuild chances are the shop used cast pistons to save a buck and that would lower your boost potential even more. dont wanna nuke a pistolio now do ya?
ORIGINAL: AdderMk2
10:1 wow, your on crack...... I wouldnt boost a motor past 9:1
ORIGINAL: ih8chevy
yeaa 308 is a 302 .40 overbored. with a supercharger u need to watch the cr. if its at a reasonable cr like below 10.1 than yea the charger will work.
It could very well be a 306 but it has a dss bottom end. i've been trying to get in touch with the guy to find out the cr. it's a completely built motor with aftermarket parts. to me the likelyhood of having 9:1 compression is unlikely. why would you go through all the trouble of rebuilding it and leave stock pistons? plus on a dynojet it's running close to 400rwhp.
The guy i just talked to said with a supercharger the compression would need to be lower not higher. plus with the built engin i have whether it be a 306 or 308 i would still be able to run 12lbs of boost without an intercooler.
YoungStangsMan
09-05-2015 07:01 PM
HorsePower99
08-26-2015 11:29 PM
