Engine Pinging
Old Nov 11, 2004 | 05:13 PM
nemethjames1's Avatar
nemethjames1
Default RE: Engine Pinging
ORIGINAL: mdvaldosta
ORIGINAL: nemethjames1
when you hear pinging, its the pistons rocking back and forth inside the cylinder due to the gas igniting prematurely
No the pinging you hear is two separate flame fronts impacting each other in the cylinder.
And if you live up in colder climate locations (below freezing most of the winter) then you will get some heavily "winterized" gas which is more likely to ping. Also in colder weather the ecu adds (or doesn't pull) as much timing due to the cooler intake temps. Run some higher octane gas or octane booster that should help - also only gettin gas from places like Shell & Chevron
i was talking to a tech at the toyota dealer and he was telling me that, it is igniting in cylinders that arent supposed to fire, and the actul ping noise you here is the pistion rocking inside the cyilnder, and if you continue to let it do that it wont be long before something ****s up..... but maybe he's wrong i suppose.... but he sure seemd to know what he was talking about
Old Nov 11, 2004 | 08:47 PM
SilverStallion's Avatar
SilverStallion
I got the same problem on my 95GT. Does yours seem to lose top end power too? It seems to run much better if i disconnect my MAS, so im thinkin that might be the problem. im gonna borrow my friends and see if it helps. If your timing is correct, you may just not be getting enough fuel. Check fuel pressure?
Old Nov 11, 2004 | 08:59 PM
JT Steeda's Avatar
JT Steeda
Ya the top end seems to be horrible when it is pinging. I allready replaced the MAF and the o2 sensors and all, ill try the octane booster, 91 octane and try lowering my timing. ill let you guys know. thanx for all the info
Old Nov 11, 2004 | 09:18 PM
racer r's Avatar
racer r
does your car get real hot? that will make it detonate also
Old Nov 11, 2004 | 09:26 PM
bobby's Avatar
bobby
yes it will, and the guy at the Toyota dealer is excactly rightits your timing, set it at 10 then take it out for a WOT test, keep bumping it up a degree, then take it for a test...... bump it up... keep doing this until it start to ping then back it off1 degree, each car is different and the timing that works best fr each car will vary
Old Nov 11, 2004 | 09:34 PM
FoxGT's Avatar
FoxGT
A toyota tech in a town near here told me mustangs had no potential & this was coming from a guy that drove a MR2.
Old Nov 11, 2004 | 11:06 PM
nemethjames1
mr2 can be fast, but it will never look as good as a foxbody
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
cardsrus1
19
Sep 15, 2015 08:37 AM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
