Finally bolted In!!!
#25
RE: Finally bolted In!!!
ORIGINAL: boof1027
Make sure you post pics and vids when you get it going. I always wondered what a chebby motor would sound like with mustang exhaust. Every camaro and trans am I hear sounds like ***.
#26
ORIGINAL: mighty90
Whats a four bolt main?
#27
ORIGINAL: Stanpower
Well good luck your on your way....Hey dosen't it smell like a bad piece of *** with the mold from the water that was in the interior of car?
#28
...managed to finish notching the oil pan...will bolt that suka on today and remount the engine for the 5th friggin time...this time it will sit 1 inch lower and fit in the bay quite nicely.
#29
I've thought about putting an LS1 in my stang but I'm just nervous about getting the speedometer and tach and all that working correctly. I'm also curious as to how the transmission would line up (so the shifter comes to the right spot) and what to do about a driveshaft.
#30
It's all a bit of a pain but all of the issues can be overcome. I'm using an automatic so its just a simple cable to get it working. If its a manual tranny then its a bit more work to hook up the clutch. dimensionaly, the trannys are similar ase ford and chev used the same transmisions (T-5).
If the tach can not be adapted I will just splice in an aftermarket one. The spedo cables are very similar. The drivexshaft is one of the minor issues...A machine shop can fab one up relatively easy..$200-$400...of course i'm ganna try it myself first and when it vibrates too much i will get a real one fabbed.
