ATTN: 351 Guru's.... need help
Old Mar 26, 2007 | 10:59 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: ATTN: 351 Guru's.... need help
Just wait till the microsquirt comes out... youll all be jealous then!
Old Mar 27, 2007 | 02:03 AM
ahittz24's Avatar
ahittz24
So R. Barn, are you running a roller or non roller motor?
Old Mar 27, 2007 | 02:06 AM
r.barn's Avatar
r.barn
ORIGINAL: ahittz24
I do have a 1994 roller cam block, so I could use standard roller lifters
and hold down plate
Old Mar 27, 2007 | 02:14 AM
89Ford's Avatar
89Ford
ORIGINAL: r.barn
ORIGINAL: ahittz24
and hold down plate
So you are or you aren't? Or am I going to have to go look up your previous posts and search for it
Old Mar 27, 2007 | 02:24 AM
grabbem88's Avatar
grabbem88
i'd run a solid set-up...mega squirt is very good...i chose pms for my personal taste reasons...mega is 400 bucks cheaper than mine,but it's what you like i guess
Old Mar 27, 2007 | 02:51 AM
black_pearl_gt's Avatar
black_pearl_gt
i have a question why cant you just drop a set of roller lifters in an older block?
Old Mar 27, 2007 | 02:55 AM
ahittz24's Avatar
ahittz24
I want to run a roller set up for many different reasons... Less internal friction = more external power, plus a roller cam allows you to run stiffer valve springs for higher lift cams. Not to mention a roller motor can rev higher safely. But I can grab this 83 motor so cheap ($150),But on the other handI found a reman 351 roller motor shortblock thats 3 hours away from my doorstep, but it has Keith Black Silvolite pistons in it and I heard those are crappy and cheaperthan hyper pistons... This motor is a complete shortblock for $899 so I dont exactly know what todo.
Old Mar 27, 2007 | 02:56 AM
vristang's Avatar
vristang
Since things got a little off topic...
ORIGINAL: ahittz24
ok, my 302 has had it, when it gets warm the oil press needle on the gauge drops off at idle and then picks back up when its it reved.... It also has a broken headbolt, so I found a 351 from an 83 f150 that is carbed and I am gonna rebuild it (maybe a 408, havent decided yet), get a lightning lower intake manifold so I can still use my cobra upper intake, swap it over to fuel injected, put some RHS Pro Action 200cc heads on it, and possibly run nitrous on it.
Here are my questions...
If I swap over to EFI, I should still be able to run my A9L ECU on this right?
I know how to calculate Fuel Injectors, I have #24 right now with a C&L MAF and that is only good top around 350 HP right? I want 400-425 so 30# should do the trick right?
I know this isnt a roller motor, Does anyone make a retro fit roller cam setup for this motor? If so, where do I find it? <--- Info that is needed the most
I know about the oil pan and pickup tube, and I am gonna swap to aAJE Racingk-member too, but is there anything else I am forgeting?
Yes, the A9L will work, but a custom tune will get you better drivability and more power.
The wilder the cam and the larger the injectors, the more likely you are to need a tune.
I ran my 408w on 30's for a while. The 30's were ok until I shortened the PW to only fire when only the intake was open.
36 would work well.
There are 2 options for getting hyd rollers in your block.
1) A reduced base circle cam
2) A set of 351w conversion hyd roller lifters.
Option 2 is greatly preferred as the reduced base cams can introduce some valve train issues.
The conversion (link bar) lifters are $475 from Crane.
I have a bunch of swap info on my site; listed in my sig.
jason
Old Mar 27, 2007 | 02:57 AM
ahittz24's Avatar
ahittz24
The block has to machined for roller lifters or you have to buy and Expensive roller lifter set up... You can but its cheaper to get a block thats made for roller lifters.
ORIGINAL: black_pearl_gt
Old Apr 19, 2007 | 02:08 AM
megascott's Avatar
megascott
Dont remember saying anything bad, but if you want me to .....................
Ok when?
How many hours putting it together did it take???????????
Depends if you did it yourself or if you buy it assembled, assembled it takes longer to get to the stock EEC than to install the Megasquirt using my adaptor board.
How many wire splices and "adaptor" boards did it take?????????
No splices, and just one "Adaptor board" which is not as big a deal as you make out.
What kind of warranty does it come with?????????
Most vendors warrantee a prebuilt Megasquirt for 90 days, butyou get free lifetime support. if youhave a problem with one of my boards, I'll fix it for free.
How many aux. inputs does it have????????
Inputs? like for what? Nitrous? Yes. Table switching? Yes. Flex fuel? Yes. Knock? Yes. An input to turn on your mood lighting....ah.....No.
Will it monitor EGT's??????????
Yes.
How many aux outputs does it have ??????????? AEM has 16!!!!!!
How many aux outputs do you need 4? 16? 32? Please explain what you need 16 more outputs for anyway?
Will it control boost????????
Yes. PWM real time boost control.
Will it control nitrous?????????
Yes. Dry or wet N2O. There's even a seperate VE table for nitrous.
Soft cut rev limter?????????
Two stage soft rev. programmable to any RPM you want.
Knock sensor provision????????
Yes. Fully programmable limits and timing adjustability.
Will it auto fuel map with wide band O2's?????
Megasquirt has AFR tables that work wth EGO correction for any wideband. Autotune with a laptopor with Automatic Mixture control.
You're wack, AEM does twice as much and is twice as expandable
to control all kinds systems from a/c and fan to boost or nitrous with
all kinds of triggers from TPS to rpm's
Yep, Were Wack. Butwe know how it works,We can mod the publically available firmware to do practically anything andthere are multiple tuning interfaces which can be DL'ed for free. Upgrades to the firmware thatprovide more functionality? Free!!
I can turn on/off my fans anywayI want to.
You need to read up on how yourEEC works. It doesn't "control"the A/C, but rather itcan disable the A/C ifneed be, Oh,I can do this with Megasquirt also, from any parameterI choose.
Yes, it cost a lot but its not some do it youself Hobby kit either.
It installs in 2mins and comes with 1 year warranty.
"MEGASQUIRT -- YOU BUILD IT YOURSELF" ......... enuf said ...............
Not neccesarily true. Youcan buildMegasquirt yourself ifYOU want to, but you don't have to.
By the way, my EEC Adaptor board works with ANY EMS, not just Megasquirt.
Megasquirt is universal, you can run it in your Lawnmower, or in your Ferrari, in fact Megasquirt has been used in both, Yes even Mustangs with V8, V6 or 4cyl.It's not specifically designed to work with your Ford, that's part of what the adaptor board does.I have a Megasquirt based single box Ford PNP system coming out soon, but probably won't be available until around the end of summer.
Scott
mtgldr
Feb 3, 2024 09:00 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
teeeeg67
Sep 1, 2015 11:53 PM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
89blueslug
Aug 10, 2015 07:20 AM
