t5 swap
RE: t5 swap
well early 86 was the non world class and the late 86 was the world class (which is much stronger) but either way as long as the 90 was originaly a manual car then it will just bolt up like the original one, the bell housing, driveshaft, and cross member are all the same
RE: t5 swap
the t-5 started in 83or 84 i believe, but it was the non worldclass and much weaker than the late 86+ t-5
ORIGINAL: thunderjet429
does 86 have t5??? what year did they use that junky S rod??? last year 85???
RE: t5 swap
hmmmm i thought 94 was the year they used world class from the factory
83-84 was the introduction of the NWC T5
85 brought the first WC T5's
90 the WCT5 was improved
93.5 it was improved again
94 the input shaft was made longer
96-04 the T5 was still backing up the 3.8l V6's and will swap directly into a 94-95 5.0 as long as you have the 94-95 5.0 bellhousing
RE: t5 swap
ORIGINAL: AdderMk2
RE: t5 swap
tranny gears are exactly the same as rearend gears
ORIGINAL: 90Lxstanger
Very good.....right on the money, yeah Adder little question on tranny gearing.is it like rean end gears the higher the number the lower or the other way? like for a tranny-is 2.95 lower or 3.35?
ORIGINAL: AdderMk2
