engine wont start
Old Nov 16, 2004 | 02:35 AM
matthewcowan's Avatar
matthewcowan
Default engine wont start
well the car was running perfectly, went to turn it on the next morning. there was a little popping sound and then nothin. the car wont even attempt to turn over. any help would be great
Old Nov 16, 2004 | 02:38 AM
slo93aod's Avatar
slo93aod
Default RE: engine wont start
popping sound?
does the car start when you jump it?
have you tried to bypass the starter siloniod?
what year?
matthewcowan
not sure if i blew a fuse or my starter or what
Old Nov 16, 2004 | 02:40 AM
matthewcowan
its a 1990, when i turn the key the battery power gauge drops to nothing. i bought a new battery so cant be the battery
Old Nov 16, 2004 | 02:41 AM
slo93aod's Avatar
slo93aod
have you tried to jump it?
have you tried to bypass the siloniod?
do you have good connections at the battery?
what year?
answer these questions and maybe someone can help you
Old Nov 16, 2004 | 02:43 AM
matthewcowan
i tried jumping it, it seems to have a good connection , same as it always did when it started, and its a 1990 lx 5.0
Old Nov 16, 2004 | 02:44 AM
slo93aod's Avatar
slo93aod
have you tried to jump the starter siloniod by the battery?
Old Nov 16, 2004 | 02:45 AM
matthewcowan
i have never done that, hows it done, thanks for the help
Old Nov 16, 2004 | 02:49 AM
slo93aod's Avatar
slo93aod
you can do it two ways:
1. put ignition key in and turn forward to the on position, just were all the dash lights come on
2. Then pop the hood and take a screw driver and jump the two large post coming of the siloniod by the battery (dont be scared it wont shock you)
or
1. same as #1 above
2. open the hood and jump the small lead on the top of the siloniod with the larger post that is closest to the firewall or seating area.
if the car starts buy another siloniod
Old Nov 16, 2004 | 02:54 AM
matthewcowan
i know i sound stupid but how do i jump it with a screw driver, where is the siloniod located
