fox vert question
fox vert question
has anyone attempted to fix the window track for the back side windows? i think i have a problem with mine, drivers side. the top edges of the 2 side windows don't line up, and yesterday my weatherstripping took the brunt of that flaw, when i dropped the top. i imagine it's quite an involved process, but i need to fix it. the back edge of the window has moved like 1 inch from the edge of the top. when i put the top back up, the left side of it tweaks or something, and hangs up, i have to shake it around to get it to come down, and yesterday, during all this, as i was putting the back window up, i had to pull the glass forward so it wouldn't hang up and stop.
RE: fox vert question
uhmm drop the top and take all teh screws out of hte 1/4 panel covering the window motor and all that.. theres like 4 screws. and then take the window motor out and idk from there.. im gonna try it this week or so and see. ill PM you
nah, those back windows just suck.
I just ordered new bushings and motors for mine.
very common for the to be out alignment or not working.
top probably just needs some grease/oil
or something adjusted, hydraulics might be going out on it too.
what is the easiest way to inspect the top's armiture? i think the "tweaking" or hanging up is inside the well, on the side. i know the motor and lines were replaced with the top, but all the arms and linkage and hinges are original. where should i begin to look for this? i'm not "convertable" inclined, so to say, lol.
its got me baffled, cuz along with the tweaking, i had to really pull forward hard to get the pins lined up with the holes.
just take the whole back seat out and the well lining
behind it, and start looking with someone making the top move for you.
gonna be a pain, good luck
I'm lucky my tuner is into Fox bodies ( has like 5 of 'em ) and
knows how to adjust and work on a lot this rinky-dink crap and where to look.
