Idling problems with a 383 stroker
Old Mar 29, 2007 | 02:47 AM
norris's Avatar
norris
Default Idling problems with a 383 stroker
Engine is a fully built 383ci stroker with 0.560 lift and 110 lobe.. 825cfm demon carb with mechanical 2ndary... trying to fine tune in the carb but what keeps happening is the car idles for about 10-15 secs at around 1000rpm, moves up to 1200rpm by itself then just takes a sh*t...
Tried playing round with the fuel regualator but no luck.. We were thinking it was the 255lph fuel pump not wired correctly.. Do u guys have any idea to what this could be?
Old Mar 29, 2007 | 03:09 AM
ampman_27's Avatar
ampman_27
Default RE: Idling problems with a 383 stroker
have you checked your vacum, sounds like a vacum leak. 383? i think your on the wrong forum, just playin
Old Mar 29, 2007 | 08:42 AM
decipha's Avatar
decipha
if the pump wasn't wired correctly it wouldn't have any pressure at all >> me thinks
i'd check the vac and the timing
Old Mar 29, 2007 | 10:33 AM
my77stang's Avatar
my77stang
yeah isnt a 383 a chevy stroker motor?[:'(][:@][&:]
anyways, 825 sounds like alot for a 383...... too much carb?? turn them screws in and lean the crap outta it - see if that clears it up
Old Mar 29, 2007 | 11:23 AM
ampman_27's Avatar
ampman_27
ya 383 is a 350 stroked, but when you need help you need help, atleast he came to ask the ford guys lol.
Old Mar 29, 2007 | 11:25 AM
my77stang's Avatar
my77stang
lol, yeah i guess chevy forums are probably pretty inbred
Old Mar 29, 2007 | 11:31 AM
92GreyGT's Avatar
92GreyGT
You aren't using a fuel injection pump on a carb are you? That may be one of your problems.
Old Mar 29, 2007 | 08:45 PM
ampman_27's Avatar
ampman_27
if he was running that much fuel pressure there would be fuel pooring out the air cleaner lol, what are you running for fuel pressure?
Old Mar 31, 2007 | 03:30 AM
norris's Avatar
norris
Well this is a friend of mines motor.. He bought it fully built and told me it was a 383 :/ Anyway, I was thinking there was probably a vacuum leak, originally the car was EFI turned to carb. Firstly he had a 302 block installed, disconnected one of the fuel lines to run the fuel through one line to reach the carb, so now the other line is just hanging there open. I had told him this may be the problem but he assured me it was deleted for sure asno fuel comes out of it..
Old Mar 31, 2007 | 03:32 AM
norris's Avatar
norris
and when it comes down to it, I'd just like to say, I've learnt ALOT more of this forum then I have with any chevy forum I've ever visited. I love the back to fundamentals approach to modding. No bull**** what so ever!
