Running Rich?
Running Rich?
Im pretty sure im runnin to much fuel because im seeing some black smoke at high rpms like around 4000-5500. My car also bogs occasionally at lower rpms and at full throttle. Is to much fuel my problem? How can I fix this? Anyway I could be wrong its just my guess, THX.
RE: Running Rich?
to adjust fuel pressure you need an adjustable pressure regulator... but its not likely your having a fuel pressure problem (rich wise) with just your mods. Maybe tps? Not sure, you gettin any codes?
RE: Running Rich?
Yea a buddy of mine has a 95 and he was sorta have the same problem, with the bogging and what not, but he got an adjustable fuel pressure regulator and he said it helped alot i dunno i just wanted to see what u guys thought, and im a newb so i dont know what tps is or what "getting any codes" is
RE: Running Rich?
yea with your mods you shouldnt be rich. when is the last tiem you had a tune up? try that along with adjusting your TPS. if youre wondering about the TPS do a search. its been discused many times
RE: Running Rich?
ORIGINAL: nemethjames1
is it possible to have codes stored, even tho the light never came on?
Also, I am having the same issue right now. I get some black smoke at the higher RPms which bugs the **** out of me. I just haven't had the time to adjust the fuel pressure. I need to pick up a voltmeter and check my TPS though. I think that might be the cause of some of it. It semed to start after I reinstalled everything after the polishing party. Oh well, bet rich than lean.[&:]
