Would There Be Any Point?
Old 03-30-2007, 09:46 PM
topendmotorsports
topendmotorsports's Avatar
Default Would There Be Any Point?
Read my sig and it'll tell you some of what's in my motor but my question is with this motor with only about 5k-6k miles on it would there be any point to put a stroker kit on it?
topendmotorsports is offline
Old 03-30-2007, 09:53 PM
5.0stanger
5.0stanger's Avatar
Default RE: Would There Be Any Point?
Well, if you were to stroke it, you would basically berebuilding your new motor again, so if you can afford it, sure do it. Just buy a blower.
5.0stanger is offline
Old 03-30-2007, 09:57 PM
topendmotorsports
I already have a blower and I'm trying to sell it cause i can't run it with a 10.5:1 compression ratio.
Old 03-30-2007, 10:14 PM
greenstreak9205
greenstreak9205's Avatar
you can run the blower with that compression, its just not the typical or optimum. you just cant run a lot of boost and you'll have to run even less timing. i guess rick anderson from anderson ford likes to run that kinda combo and he's a pretty credible guy. just sayin that its not like you cant do it, you just have to b careful and ask sombody that has done it before what they think bout it
greenstreak9205 is offline
my77stang
my77stang's Avatar
hmm, build a 331 with lower compression and then make use of the supercharger
my77stang is offline
Old 03-30-2007, 10:23 PM
topendmotorsports
Ok. I talked to Rick Erdman from Amazon Tuning Solutions in Anderson, SC and he said it's difficult to do with a 10.5:1 compression considering the blower i have is a Vortech T-Trim with only 12lb and 17lb pulley's.
Old 03-30-2007, 10:32 PM
my77stang
my77stang's Avatar
hard to believe you couldnt fab up a different pulley system to further reduce the boost. anyways, theres always methenol injection
Old 03-30-2007, 10:41 PM
topendmotorsports
Thats a good idea. I'm new to methanol so could you explain that to me?
Old 03-30-2007, 10:47 PM
I3atR!ce
I3atR!ce's Avatar
if your going to run that blower, dich the e cam and go for a custom cam, with your set up (331, 302 or 347) and a fat blower, you will definetly want one.
I3atR!ce is offline
Old 03-30-2007, 10:50 PM
topendmotorsports
Well if I sell the blower I could stroke my motor but what would be the point with only 5k miles on it? And the blower I have is a Vortech T-Trim so yea, it's one heck of a centrifugal blower.
Quick Reply: Would There Be Any Point?
