vid of idle, ticking noise what is it?
Old Mar 31, 2007 | 05:25 PM
Goosepoop302's Avatar
Goosepoop302
Default vid of idle, ticking noise what is it?
http://s80.photobucket.com/albums/j1...t=MOV00048.flv
hope that link worked if not let me know. you may have to have your volume up pretty load to hear it but its a higher pitched sound i thought as an exhaust leak but i cant seem to figure it out. Also my car consistantly runs at about a 2k idle after i rev it up and wont go back down till it sits for a minute, any ideas on how ot fix that? i havnt had the car dynoed yet but its commin soon!
Old Mar 31, 2007 | 05:29 PM
ooticamitica's Avatar
ooticamitica
Default RE: vid of idle, ticking noise what is it?
sounds like valve tap, if your nto running high octane gas put a few tanks in it.
Old Mar 31, 2007 | 05:32 PM
Goosepoop302
i run 92 in it. could it be due to timing,, any other ideas?
Old Mar 31, 2007 | 05:38 PM
ooticamitica
im not too sure how to fix it besides what i said, the tune will def make the car run better, the timing may fix that.
Old Mar 31, 2007 | 05:45 PM
Goosepoop302
Also my idle stays high for a few seconds after barly touching the gas anytime. i thought that this may be a vac leak but im not sure
Old Mar 31, 2007 | 05:46 PM
ooticamitica
well yea, everyones does when its first started, than when it gets warm the throttle response is normal(for me at least)
Old Mar 31, 2007 | 06:39 PM
Goosepoop302
anyone with a HCI done have any input? i cna see that the elbow for my TB hits my valve covers, i think this is causing an vac leak. im htinking a small spacer would fix that issue but why would trick flow sell that **** andit not fit together properly?
Old Mar 31, 2007 | 07:10 PM
whiteout 5.0's Avatar
whiteout 5.0
the mounting holes werent even fully drilled out on my trickflow intakes quality wasnt great but the runners were exellent
Old Mar 31, 2007 | 07:31 PM
my77stang's Avatar
my77stang
is this something you just got together and its making this noise or was everything ok and all of a sudden it delevoped a noise?
if you just got it together, i would think maybe rocker arms out of adjustment
Old Mar 31, 2007 | 07:48 PM
Goosepoop302
they were all JUST re adjusded like 2 days ago. they were noisy as hell prior to that. i think that i have a vac leak in my system cause the egr stuff hits my valve covers and actually dented one so im ordering a spacer, hope it help.
