331 question
#21
RE: 331 question
stinkinlincoln what kind of setup are u runnin just curious cause i think i am just gonna do it think i need to talk to full auto he quoted me somewhere around 900 for the scat kit to my door with scat rods and crank,probe pistons
#23
RE: 331 question
if it were me i would run 30lbs. injectors and a 80mm vmas into a accufab 75mm at the blade and 92mm at the intake entry race style throttle body. i just installed all this plus the AFR 4" powerpipe to my setup and it made a big diffrence. im only running a 306 with 24lbs. injectors
#27
RE: 331 question
what kind of tfs heads you got? but you really need a track heat intake and a bigger cam than the stage one where its only good to about 5500 30 lb injectors and go at least a 75 mm throttle body the setup youve got will work with the stroker but ya wont get the full potential out of it. youre heads cam and intake are probably a pretty good match but im guessin you gonna be aroun the 400-425 hp range at the flywheel
#30
RE: 331 question
yea i was already thinking about upgrading the cam already wanted a little bigger cam lift/duration?? what is the rest of the numbers for that cam i have heard good things about their cams??
