drag radial size?
Old Apr 2, 2007 | 11:22 PM
1bad87's Avatar
1bad87
Default drag radial size?
well for now i want to mount a set of drag radials on 2 of my stock 10hole wheels i have laying in the shed to use at the track. my question is, what size drag radial should i go with and what brand? i dont know much about them but i real alot about the MT et streets.
thanks in advance fellas
Old Apr 2, 2007 | 11:25 PM
primetime5.0's Avatar
primetime5.0
Default RE: drag radial size?
I had a set of 235-60-15's on some old turbines I had, they worked well
Old Apr 2, 2007 | 11:26 PM
ZachW04Stang's Avatar
ZachW04Stang
With your mods I'd look into a set of 8 inch wide wheels and getting 275's. You might need a 28 inch tire for those 3.73's with that super charger in front of them. You could get a set of 28x10.5 inch slicks on the 10 holes no problem especially if the wheels are just for the track.
Old Apr 2, 2007 | 11:32 PM
1bad87's Avatar
1bad87
yeah with the 373's im trappin at the very top of 4th so im guessin i want a tire close to the same size as my street tires. right now i have 255/45's on there.
fri night went 13.0 at 111mph with a 2.175 60ftand was spinnin some out of the hole. im goin for 12's on streets still before i put on the dr's
Old Apr 2, 2007 | 11:47 PM
1bad87's Avatar
1bad87
will those 28x10.5s fit on the car with it having the c springs on it? also im guessin the quadshocks will need to be removed.
Old Apr 3, 2007 | 02:14 AM
dimebag's Avatar
dimebag
yo man, i have the mt et street drag radials... 235/60/15 on turbines... they make a 255/xx/15 ... id go w. that...
Sep 25, 2015 06:58 PM
Sep 25, 2015 06:42 PM
Sep 25, 2015 06:30 PM
