good aftermarket block?
what kinda block should i get. ive decided to build my motor on the side, all new parts, while its out of the car. Should i get a dart block? how about shortblocks? im looking to run a 347, is there any company that sells shortblocks that are strong and not overly pricey?
ORIGINAL: FullAuto
Use the Dart block. There are companies that make shortblocks with aftermarket blocks. Don't buy them. Buy all your own parts and have someone local put it together for you.
Dart block and Man-O-War (Needing machining) $2200-2400. (Add roughly $500 for all of the machining needed).
IF you are not planning on exceeeding 500hp, why not buy a sportsman block? you can buy one for a third of the cost of a Dart/World and never have an issue. Or if you are going to build on an aftermarket block go ahead and buy a Windsor, the block is going to cost you about the same and you will never have a need to up-grade your platform.
