Piston, Forged, Flat Top, 4.030 in. Bore, 1.5mm, 1.5mm, 4.0mm Ring Grooves, Ford, 302, Each
[ul]Check to make sure this part fits your application [/ul]
[/align]Higher compression, longer life.
These Power Forged pistons from Speed-Pro are designed to fit tight, thanks to a special aluminum alloy that doesn't expand as much as other alloys. They'll provide the stability and ring control you need, plus the strength you want. Speed-Pro pistons also feature ribbed skirts for better oil retention, and even included new wrist pins! [/align]Back to Search Results [/align]
i am lookin for some decent forged pistons to get for my new motor the pistons gaskets and machine work is pretty much what i got left to get i have twisted wedge heads so i need a piston with valve reliefs for them i was lookin at the rebuild kit from summit with these pistons in it dont want to order them if they wont work any body help anybody runnin these pistons with the twisted wedge heads
They'll work. You'll just be limiting yourself as if it were a stock shortblock. You could buy something like a Probe piston with dual valve reliefs in it.
