T5 fluid
ORIGINAL: 94gtcoupe
i rebuild alot of these trannys and regular mercon 3 isn't realy all that good of a fluid... and GM syncromesh can be bought at a GM dealer, hence the name of the fluid
mobil one synthetic, is prolly carried at your work, the GM stuff was like 35$ and i have some left over
, just stick with a decent name brand and you'll be ok with the fluid... don't just get like the cheap "house" brand ****
I bought some penzoil syncromesh today, hope that'll do that job. I just gotta wait for another quart to come in cuz there was only 2, so i need another 1.5 pints. Also bought some lucas 80-90 for the rear. I should have her out when this stupid a$$ ohio weather goes away.
ive been using that b&m trick shift fluid and its preety good. seems the same as all the top brands though, its just greenish blue instead of red. i have seen dyno proof that royal purple in the motor,tranny and rearend will add 8 horse power.
*** hat, i was gunna ask y u needed another 1.5 qts. but you went from using quarts to pints lol, didn't they teach you in school to keep your measuments in the same basic units? ITC Quarts OR Pints not both[:'(].... and just in case u didn't know the tranny take about 2.75 qts.
ORIGINAL: Ninety5five0
did u use the right royal purple? they do make more than one ATF and more than one manual fluid
ORIGINAL: Tberg725
i run dex III in my trans but i herd that gm syncromesh is the best, i frown on royal purple because right after i switched toit my trans blew
jwog666
Dec 27, 2021 08:09 PM
Sep 25, 2015 06:42 PM
lol i know u was j/k
