random stall
Old Nov 25, 2004 | 12:06 AM
SilverStallion's Avatar
SilverStallion
Default random stall
My car runs fine, but every once and a while when im just idling my rpms will drop down to about 500 for a sec, and sometimes stall. Haven't noticed any other problems with it. Anyone know what the problem could be? or what i should check? oh, its a 95 GT, EFI.
Old Nov 25, 2004 | 12:10 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: random stall
tell tale sign of an IAC problem
Old Nov 25, 2004 | 12:53 AM
bobby's Avatar
bobby
either your IAC or you need to clean you MAF
Old Nov 25, 2004 | 12:21 PM
roundman's Avatar
roundman
I would clean both the IAC and throttle body and see if this doesn't help cure the trouble.
Old Nov 25, 2004 | 02:55 PM
SilverStallion
Well i sure hope its not the MAF cause i just got a new one, but i'll clean the IAC and throttle body and see how it goes. Thanks.
Old Nov 25, 2004 | 05:24 PM
Predator's Avatar
Predator
I have a friend with an 88 and he says his idle will dip down then come back up and so forth. Well he cleaned out his idle throttle body, and he said that worked (for about 10k miles), until it got dirty again.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
trashxtrash
Sep 20, 2015 10:49 PM
